Passive UHF RFID Yarn For Temperature Sensing Applications - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper presents an Ultra High Frequency (UHF) Radio Frequency IDentification (RFID) temperature sensor integrated into a textile yarn. The tag system consists of a thermistor of which the resistance is sensitive to temperature variation. The theoretical working principle is detailed and validated using electromagnetic simulation. The UHF RFID temperature sensor is fabricated using the E-Thread® technology. Experimental results demonstrate the potential of the sensor for detecting a temperature variation comprised between 25°C and 70°C through a variation of the reading distance between 4.5 meters to 6.2 meters.
RFID_TA_2021_SB.pdf (607.13 Ko) Télécharger le fichier
hal-03389473 , version 1 (21-10-2021)
Sofia Benouakta, Florin Hutu, Yvan Duroc. Passive UHF RFID Yarn For Temperature Sensing Applications. RFID-TA 2021 - 11th IEEE international Conference on RFID Technology and Applications, Oct 2021, Dehli, India. pp.1-3, ⟨10.1109/RFID-TA53372.2021.9617438⟩. ⟨hal-03389473⟩
45 Consultations
244 Téléchargements
