Automated and Reproducible Application Traces Generation for IoT Applications - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Nina Santi
Rémy Grünblatt
  • Fonction : Auteur
  • PersonId : 1114292
Brandon Foubert
Aroosa Hameed
  • Fonction : Auteur
  • PersonId : 1114293
John Violos
  • Fonction : Auteur
  • PersonId : 1114294
Aris Leivadeas
  • Fonction : Auteur
  • PersonId : 1114295
In this paper, we investigate and present how to generate application traces of IoT (Internet of Things) Applications in an automated, repeatable and reproducible manner. By using the FIT IoT-Lab large scale testbed and relying on state-of-the-art software engineering techniques, we are able to produce, collect and share artifacts and datasets in an automated way. This makes it easy to track the impact of software updates or changes in the radio environment both on a small scale, e.g. during a single day, and on a large scale, e.g. during several weeks. By providing both the source code for the trace generation as well as the resulting datasets, we hope to reduce the learning curve to develop such applications and encourage reusability as well as pave the way for the replication of our results. While we focus in this work on IoT networks, we believe such an approach could be of used in many other networking domains.
Traces_FIT(1).pdf (2.49 Mo) Télécharger le fichier
hal-03390693 , version 1 (21-10-2021)
Nina Santi, Rémy Grünblatt, Brandon Foubert, Aroosa Hameed, John Violos, et al.. Automated and Reproducible Application Traces Generation for IoT Applications. Q2SWinet 2021 - 17th ACM Symposium on QoS and Security for Wireless and Mobile Networks, Nov 2021, Alicante, Spain. pp.1-8, ⟨10.1145/3479242.3487321⟩. ⟨hal-03390693⟩
163 Consultations
180 Téléchargements
