Optimizing Multi-Taper Features for Deep Speaker Verification - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Signal Processing Letters Année : 2021
Multi-taper estimators provide low-variance power spectrum estimates that can be used in place of the windowed discrete Fourier transform (DFT) to extract speech features such as mel-frequency cepstral coefficients (MFCCs). Even if past work has reported promising automatic speaker verification (ASV) results with Gaussian mixture model-based classifiers, the performance of multi-taper MFCCs with deep ASV systems remains an open question. Instead of a static-taper design, we propose to optimize the multi-taper estimator jointly with a deep neural network trained for ASV tasks. With a maximum improvement on the SITW corpus of 25.8% in terms of equal error rate over the static-taper, our method helps preserve a balanced level of leakage and variance, providing more robustness.
Multitaper_IEEE_SPL.pdf (286.15 Ko) Télécharger le fichier
hal-03394152 , version 1 (22-10-2021)
Xuechen Liu, Md Sahidullah, Tomi Kinnunen. Optimizing Multi-Taper Features for Deep Speaker Verification. IEEE Signal Processing Letters, 2021, 28, pp.2187 - 2191. ⟨10.1109/LSP.2021.3122796⟩. ⟨hal-03394152⟩
37 Consultations
80 Téléchargements
