Energy-Efficient, Reliable and QoS-Aware Task Mapping on Cyber-Physical Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport Technique) Année : 2021
Cyber-Physical Systems (CPS) usually consist of a set of embedded systems (CPS nodes) connected through wireless communication, providing multiple functionalities that support different types of applications. During CPS deployment, application tasks are mapped on the CPS nodes with the objective of enhancing real-time performance, energy efficiency, and execution reliability. To satisfy these requirements, effective task mapping approaches should be designed based on different types of tasks, platforms, applications, and system requirements. In this paper, we provide a comprehensive survey regarding the task mapping methods in CPS.
Energy-Efficient, Reliable and QoS-Aware Task Mapping on Cyber-Physical Systems.pdf (3.95 Mo) Télécharger le fichier
hal-03419313 , version 1 (08-11-2021)
  • HAL Id : hal-03419313 , version 1
Lei Mo, Angeliki Kritikakou, Xinmei Li. Energy-Efficient, Reliable and QoS-Aware Task Mapping on Cyber-Physical Systems. [Technical Report] IEEE Technical Committee on Cyber-Physical Systems. 2021. ⟨hal-03419313⟩
96 Consultations
76 Téléchargements
