A resource management survey for mission critical and time critical applications in multi access edge computing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ITU Journal on Future and Evolving Technologies Année : 2021
Nina Santi
Multiaccess Edge Computing (MEC) brings additional computing power in proximity of mobile users, reducing latency, saving energy and alleviating the network's bandwidth. This proximity is beneficial, especially for mission-critical applications where each second matters, such as disaster management or military operations. Moreover, it enables MEC resources embedded on mobile units like drones or robots that are flexible to be deployed for missioncritical applications. However, the MEC servers are capacity-limited and thus need an acute management of their resources. The mobile resources also need a smart deployment scheme to deliver their services efficiently. In this survey, we review mission-critical applications, resource allocation and deployment of mobile resources techniques in the context of the MEC. First, we introduce the technical specifics and uses of MEC in mission-critical applications to highlight their needs and requirements. Then, we discuss the resource allocation schemes for MEC and assess their fit depending on the application needs. In the same fashion, we finally review the deployment of MEC mobile resources. We believe this work could serve as a helping hand to design efficient MEC resource management schemes that respond to challenging environments such as mission-critical applications.
Ressource_allocation_in_MEC(1).pdf (737.07 Ko) Télécharger le fichier
hal-03420193 , version 1 (09-11-2021)
  • HAL Id : hal-03420193 , version 1
Nina Santi, Nathalie Mitton. A resource management survey for mission critical and time critical applications in multi access edge computing. ITU Journal on Future and Evolving Technologies, 2021, Volume 2 (2021), Issue 2., 2 (2). ⟨hal-03420193⟩
Collections
INRIA INRIA2
394 Consultations
191 Téléchargements
