Optical scrambling system for document authentication by image decryption - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Optics Letters Année : 2020
Vincent Nourrit
J.-L. de Bougrenet de La Tocnaye
  • Fonction : Auteur
  • PersonId : 1005168
  • IdRef : 069341664
The continuous development of new authentication techniques is necessary to prevent illegal data access from unauthorized users or counterfeiting. In this paper, we present a simple optical method to decode encrypted images using a multi-scopic optical system. The method uses a scrambled lens-let array which provides a high level of security. In a simple configuration, the encrypted image is scrolled in front of the multi-scopic imaging system. Due to a particular arrangement of lens-lets, the image will only be correctly imaged at a unique position with respect to the imager. Experimental demonstrations are presented and potential applications discussed.
Mots clés
Fichier non déposé
hal-03428728 , version 1 (15-11-2021)
M. Dejean, Vincent Nourrit, J.-L. de Bougrenet de La Tocnaye. Optical scrambling system for document authentication by image decryption. Optics Letters, 2020, 45 (2), pp.347. ⟨10.1364/OL.381297⟩. ⟨hal-03428728⟩
21 Consultations
0 Téléchargements
