Identification of isolated or mixed strains from long reads: a challenge met on Streptococcus thermophilus using a MinION sequencer - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Microbial Genomics Année : 2021
This study aimed to provide efficient recognition of bacterial strains on personal computers from MinION (Nanopore) long read data. Thanks to the fall in sequencing costs, the identification of bacteria can now proceed by whole genome sequencing. MinION is a fast, but highly error-prone sequencing device and it is a challenge to successfully identify the strain content of unknown simple or complex microbial samples. It is heavily constrained by memory management and fast access to the read and genome fragments. Our strategy involves three steps: indexing of known genomic sequences for a given or several bacterial species; a request process to assign a read to a strain by matching it to the closest reference genomes; and a final step looking for a minimum set of strains that best explains the observed reads. We have applied our method, called ORI , on 77 strains of Streptococcus thermophilus . We worked on several genomic distances and obtained a detailed classification of the strains, together with a criterion that allows merging of what we termed ‘sibling’ strains, only separated by a few mutations. Overall, isolated strains can be safely recognized from MinION data. For mixtures of several non-sibling strains, results depend on strain abundance.
2021_MinION_STH.pdf (2.19 Mo) Télécharger le fichier
hal-03444296 , version 1 (24-11-2021)
Paternité
Grégoire Siekaniec, Emeline Roux, Téo Lemane, Eric Guédon, Jacques Nicolas. Identification of isolated or mixed strains from long reads: a challenge met on Streptococcus thermophilus using a MinION sequencer. Microbial Genomics, 2021, 7 (11), pp.1-14. ⟨10.1099/mgen.0.000654⟩. ⟨hal-03444296⟩
126 Consultations
87 Téléchargements
