Tail and quantile estimation for real-valued β-mixing spatial data - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2021
Tchamiè Tchazino
  • Fonction : Auteur
Aliou Diop
  • Fonction : Auteur
  • PersonId : 758987
  • IdRef : 113412894
This paper deals with extreme-value index estimation of a heavy-tailed distribution of a spatial dependent process. We are particularlyinterested in spatial rare events of a β−mixing process. Given a sta-tionary real-valued multidimensional spatial process {X_i,i ∈ Z^N}, weinvestigate its heavy-tail index estimation. Asymptotic properties ofthe corresponding estimator are established under mildmixingcondi-tions. The particularity of the tail proposed estimator is based on thespatial nature of the sample and its unbiased and reduced variance prop-erties compared to well known tail index estimators. Extreme quantileestimation is also deduced. A numerical study on synthetic and realdatasets is conducted to assess the finite-sample behaviour of the pro-posed estimators.
Article1.pdf (793.46 Ko) Télécharger le fichier
hal-03457114 , version 1 (30-11-2021)
Copyright (Tous droits réservés)
  • HAL Id : hal-03457114 , version 1
Tchamiè Tchazino, Sophie Dabo-Niang, Aliou Diop. Tail and quantile estimation for real-valued β-mixing spatial data. 2021. ⟨hal-03457114⟩
80 Consultations
40 Téléchargements
