Multi-label Deep Convolutional Transform Learning for Non-intrusive Load Monitoring - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ACM Transactions on Knowledge Discovery from Data (TKDD) Année : 2022
The objective of this letter is to propose a novel computational method to learn the state of an appliance (ON / OFF) given the aggregate power consumption recorded by the smart-meter. We formulate a multi-label classification problem where the classes correspond to the appliances. The proposed approach is based on our recently introduced framework of convolutional transform learning. We propose a deep supervised version of it relying on an original multi-label cost. Comparisons with state-of-the-art techniques show that our proposed method improves over the benchmarks on popular non-intrusive load monitoring datasets.
TKDD.pdf (638.67 Ko) Télécharger le fichier
hal-03463403 , version 1 (02-12-2021)
Shikha Singh, Emilie Chouzenoux, Giovanni Chierchia, Angshul Majumdar. Multi-label Deep Convolutional Transform Learning for Non-intrusive Load Monitoring. ACM Transactions on Knowledge Discovery from Data (TKDD), 2022, 16 (5), pp.1-6. ⟨10.1145/3502729⟩. ⟨hal-03463403⟩
89 Consultations
139 Téléchargements
