On the Dual Interpretation of Nouns as Types and Predicates in Semantic Type Theories - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
William Babonnaud
In order to mediate the debate on whether common nouns are better interpreted as types or as predicates in type-theoretical semantic frameworks, the present paper shows that type theories whose models in category theory are toposes have access to a property drawing a one-to-one correspondence between first-order predicates and base types, thus enabling more flexibility for common noun interpretation. Using this flexibility and linguistic arguments based on negative predications, a subsequent proposal is made to interpret nouns as predicates with refined argument types.
typrd_final.pdf (242.36 Ko) Télécharger le fichier
hal-03468606 , version 1 (07-12-2021)
  • HAL Id : hal-03468606 , version 1
William Babonnaud. On the Dual Interpretation of Nouns as Types and Predicates in Semantic Type Theories. ESSLLI 2021 - 2nd Workshop on Computing Semantics with Types, Frames and Related Structures, Jul 2021, Virtual, Netherlands. ⟨hal-03468606⟩
66 Consultations
50 Téléchargements
