Computing the 4-Edge-Connected Components of a Graph in Linear Time
We present the first linear-time algorithm that computes the 4-edge-connected components of an undirected graph. Hence, we also obtain the first linear-time algorithm for testing 4-edge connectivity. Our results are based on a linear-time algorithm that computes the 3-edge cuts of a 3-edge-connected graph G, and a linear-time procedure that, given the collection of all 3-edge cuts, partitions the vertices of G into the 4-edge-connected components.
Informatique [cs]
