Centralized and Decentralized Routing Solutions for Present and Future Space Information Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Network Année : 2021
Space Information Networks (SINs) are pushing the boundaries of networking into near-Earth orbit and beyond. Nevertheless, the harsh and costly space context forces most riskprone missions to be designed with minimal chance of failure. The careful consideration of routing protocols used to connect the fleet is by no means the exception. Although decentralized SIN routing schemes received most of the attention of the research community, centralized approaches are captivating the industry, as these come with tighter control and do enable troubleshooting of valuable space assets from a mission control center on ground. In this paper, we settle the matter by qualitatively and quantitatively comparing both SIN paradigms. We propose two novel centralized routing schemes, and evaluate their resulting performance against Contact Graph Routing (CGR), the decentralized state-of-the-art. In this evaluation, computational effort, memory utilization, and energy consumption are taken as figures of merit. The outcome provides compelling evidence that centralized routing schemes can safely, successfully and efficiently connect SINs with up to 10k daily contacts, while CGR can be better entrusted with larger-scale SIN deployments.
2021-IEEENetwork-Centralized-Distributed-Routing.pdf (2.26 Mo) Télécharger le fichier
hal-03494101 , version 1 (18-12-2021)
Juan Andrés A Fraire, Elías L Gasparini. Centralized and Decentralized Routing Solutions for Present and Future Space Information Networks. IEEE Network, 2021, 35 (4), pp.110-117. ⟨10.1109/MNET.011.2100102⟩. ⟨hal-03494101⟩
56 Consultations
446 Téléchargements
