Customizing Number Representation and Precision - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2022
There is a growing interest in the use of reduced-precision arithmetic, exacerbated by the recent interest in artificial intelligence, especially with deep learning. Most architectures already provide reduced-precision capabilities (e.g., 8-bit integer, 16-bit floating point). In the context of FPGAs, any number format and bit-width can even be considered. In computer arithmetic, the representation of real numbers is a major issue. Fixed-point (FxP) and floating-point (FlP) are the main options to represent reals, both with their advantages and drawbacks. This chapter presents both FxP and FlP number representations, and draws a fair a comparison between their cost, performance and energy, as well as their impact on accuracy during computations. It is shown that the choice between FxP and FlP is not obvious and strongly depends on the application considered. In some cases, low-precision floating-point arithmetic can be the most effective and provides some benefits over the classical fixed-point choice for energy-constrained applications.
custom_precision.pdf (2.46 Mo) Télécharger le fichier
reference.bib (25.93 Ko) Télécharger le fichier
hal-03494872 , version 1 (07-12-2022)
Olivier Sentieys, Daniel Menard. Customizing Number Representation and Precision. Approximate Computing Techniques - From Component- to Application-Level, Springer, 2022, ⟨10.1007/978-3-030-94705-7_2⟩. ⟨hal-03494872⟩
62 Consultations
69 Téléchargements
