A Region-Based Bit-Shuffling Approach Trading Hardware Cost and Fault Mitigation Efficiency - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Due to transistor shrinking and core number increasing in System-on-Chip (SoC), fault tolerance has become essential. Indeed, faults occurring to Network-on-Chips (NoCs) of those systems have a significant impact, due to the high amount of data crossing the NoC for communication. However, existing fault correction approaches cannot efficiently address several permanent faults on NoC, due to their high hardware costs. To mitigate the impact of faults, existing works shuffle the bits inside a flit, transferring the impact of faults on the least significant bits. However, such approaches are applied at a fine-grained level, providing fault mitigation efficiency but with significant hardware costs. To address this limitation, this work proposes a region-based bit-shuffling technique, applied at a coarse-grain level, that trades off fault mitigation efficiency in order to save hardware costs. The obtained results show that the area and power overheads can be reduced from 48% to 33% and from 34% to 22%, respectively, with a small impact on the Mean Square Error (MSE).
MercierRomain_BiSu_DFT_SHORT_paper.pdf (880.37 Ko) Télécharger le fichier
hal-03500395 , version 1 (22-12-2021)
Romain Mercier, Cédric Killian, Angeliki Kritikakou, Youri Helen, Daniel Chillet. A Region-Based Bit-Shuffling Approach Trading Hardware Cost and Fault Mitigation Efficiency. DFT 2021 - 34th IEEE International Symposium on Defect and Fault Tolerance in VLSI and Nanotechnology Systems, Oct 2021, athens, Greece. pp.1-4, ⟨10.1109/DFT52944.2021.9568366⟩. ⟨hal-03500395⟩
37 Consultations
50 Téléchargements
