Data integration in logic-based models of biological mechanisms - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Current Opinion in Systems Biology Année : 2021
Discrete, logic-based models are increasingly used to describe biological mechanisms. Initially introduced to study gene regulation, these models evolved to cover various molecular mechanisms, such as signaling, transcription factor cooperativity, and even metabolic processes. The abstract nature and amenability of discrete models to robust mathematical analyses make them appropriate for addressing a wide range of complex biological problems. Recent technological breakthroughs have generated a wealth of high-throughput data. Novel, literature-based representations of biological processes and emerging algorithms offer new opportunities for model construction. Here, we review up-to-date efforts to address challenging biological questions by incorporating omic data into logic-based models and discuss critical difficulties in constructing and analyzing integrative, large-scale, logicbased models of biological mechanisms.
1-s2.0-S2452310021000809-main (1).pdf (692.55 Ko) Télécharger le fichier
Origine : Publication financée par une institution
hal-03515653 , version 1 (06-01-2022)
Benjamin A Hall, Anna Niarakis. Data integration in logic-based models of biological mechanisms. Current Opinion in Systems Biology, 2021, 28, pp.100386. ⟨10.1016/j.coisb.2021.100386⟩. ⟨hal-03515653⟩
85 Consultations
90 Téléchargements
