Does temperature shift justify microalgae production under greenhouse? - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Algal Research - Biomass, Biofuels and Bioproducts Année : 2022
We analyze the influence of greenhouses in the cultivation of phytoplankton. For this we propose a model for the marine green algae Tetraselmis suecica, and adapt it to four other species (Spirulina platensis, Dunaliella salina, Phaeodactylum tricornutum and Chlorella vulgaris). Experiments under a greenhouse were carried out for the marine green algae Tetraselmis suecica, shifting the temperature of two raceways compared to a reference raceway with free evolving temperature. The productivity model was then parametrized and validated accounting for the recorded evolution of temperature and light. The yearly raceway pond production and the benefit of greenhouse usage were assessed under different scenarios for the five considered species. At year scale, greenhouse efficiency is notable only for few species, e.g. Spirulina platensis, where productivity can be increased by 20%. Based on these results, cultivation under greenhouse is beneficial mainly to protect the culture against contamination and to increase productivity in cold regions for species susceptible to photoinhibition with optimal growth in high temperatures. Rotation of the cultivated species is also a good strategy to improve annual productivity.
Biotechnologies
Effects_of_temperature_in_raceway_production_of_microalgae.pdf (983.94 Ko) Télécharger le fichier
hal-03522868 , version 1 (17-05-2022)
Bruno Assis Pessi, Eric Pruvost, Amélie Talec, Antoine Sciandra, Olivier Bernard. Does temperature shift justify microalgae production under greenhouse?. Algal Research - Biomass, Biofuels and Bioproducts, 2022, 61, pp.102579. ⟨10.1016/j.algal.2021.102579⟩. ⟨hal-03522868⟩
223 Consultations
121 Téléchargements
