What Can Statistics Tell About the Gender Gap in ICT? Tracing Men and Women’s Participation in the ICT Sector Through Numbers - Archive ouverte HAL Access content directly
Conference Papers Year : 2020
(1) , (1)
1
Which narratives can statistics tell about men and women’s participation in ICT? The question is relevant across the western world showing a pattern of more men than women in ICT work. This chapter presents an analysis of available statistics that contribute to an image of women’s participation in ICT work and education. The scope of the study is European countries with an emphasis on Norway, however, we also present statistics from OECD. The statistics confirm that the gender imbalance in ICT work is significant, suggesting that monitoring this field is important. The analysis also reveals challenges and gaps in the material, for instance the challenge of finding comparable numbers, a reduced use of gender as a variable in later years, difficulties in identifying the gendered structures of ICT due to a mixture of occupational fields for some of the relevant numbers, while other issues found to be relevant in qualitative studies are not represented in the available statistics. The monitoring of gendered structures of ICT work can be improved by developing statistics that better can capture inequalities and hierarchies. The findings also suggest that qualitative research is an important complement and correction to statistical overviews, in particular for identifying factors that alone and together contribute to gender inequalities in ICT.
497045_1_En_30_Chapter.pdf (554.77 Ko) Télécharger le fichier
Dates and versions
hal-03525263 , version 1 (13-01-2022)
Attribution - CC BY 4.0
Identifiers
Cite
Morten Simonsen, Hilde G. Corneliussen. What Can Statistics Tell About the Gender Gap in ICT? Tracing Men and Women’s Participation in the ICT Sector Through Numbers. 14th IFIP International Conference on Human Choice and Computers (HCC), Sep 2020, Tokyo, Japan. pp.379-397, ⟨10.1007/978-3-030-62803-1_30⟩. ⟨hal-03525263⟩
15 View
0 Download
Share
