The Heavy-Tail Phenomenon in SGD - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In recent years, various notions of capacity and complexity have been proposed for characterizing the generalization properties of stochastic gradient descent (SGD) in deep learning. Some of the popular notions that correlate well with the performance on unseen data are (i) the `flatness' of the local minimum found by SGD, which is related to the eigenvalues of the Hessian, (ii) the ratio of the stepsize $\eta$ to the batch-size $b$, which essentially controls the magnitude of the stochastic gradient noise, and (iii) the `tail-index', which measures the heaviness of the tails of the network weights at convergence. In this paper, we argue that these three seemingly unrelated perspectives for generalization are deeply linked to each other. We claim that depending on the structure of the Hessian of the loss at the minimum, and the choices of the algorithm parameters $\eta$ and $b$, the SGD iterates will converge to a \emph{heavy-tailed} stationary distribution. We rigorously prove this claim in the setting of quadratic optimization: we show that even in a simple linear regression problem with independent and identically distributed data whose distribution has finite moments of all order, the iterates can be heavy-tailed with infinite variance. We further characterize the behavior of the tails with respect to algorithm parameters, the dimension, and the curvature. We then translate our results into insights about the behavior of SGD in deep learning. We support our theory with experiments conducted on synthetic data, fully connected, and convolutional neural networks.
Fichier non déposé
hal-03530319 , version 1 (17-01-2022)
  • HAL Id : hal-03530319 , version 1
Mert Gurbuzbalaban, Umut Şimşekli, Lingjiong Zhu. The Heavy-Tail Phenomenon in SGD. ICML2021 - Thirty-eighth annual conference on International Conference on Machine Learning, Jul 2021, Virtual, France. ⟨hal-03530319⟩
44 Consultations
0 Téléchargements
