Efficient and Expressive Bytecode-Level Instrumentation for Java Programs
We present an efficient and expressive tool for the instrumentation of Java programs at the bytecodelevel. BISM (Bytecode-Level Instrumentation for Software Monitoring) is a lightweight Java bytecode instrumentation tool that features an expressive high-level control-flow-aware instrumentation language. The language is inspired by the aspect-oriented programming paradigm in modularizing instrumentation into separate transformers, that encapsulate joinpoint selection and advice inlining. BISM allows capturing joinpoints ranging from bytecode instructions to methods execution and provides comprehensive static and dynamic context information. It runs in two instrumentation modes: build-time and load-time. BISM also provides a mechanism to compose transformers and automatically detect their collision in the base program. Transformers in a composition can control the visibility of their advice and other instructions from the base program. We show several example applications for BISM and demonstrate its effectiveness using three experiments: a security scenario, a financial transaction system, and a general runtime verification case. The results show that BISM instrumentation incurs low runtime and memory overheads.
