Improving Support-Minors rank attacks: applications to GeMSS and Rainbow - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The Support-Minors (SM) method has opened new routes to attack multivariate schemes with rank properties that were previously impossible to exploit, as shown by the recent attacks of [35] and [7] on the NIST candidates GeMSS and Rainbow respectively. In this paper, we study this SM approach more in depth, which allows us first to propose a greatly improved attack on GeMSS and also to define a more realistic cost model to evaluate the memory complexity of an XL strategy on the SM system using the Block-Wiedemann algorithm. Our new attack on GeMSS makes it completely unfeasible to repair the scheme by simply increasing the size of its parameters or even applying the projection technique from [31], as the signing time would be increased in a considerable way. Also, in our refined cost model, the rectangular MinRank attack from [7] does indeed reduce the security of all Round 3 Rainbow parameter sets below their targeted security strengths, contradicting the lower bound claimed by [41] using the same memory cost model.
GeMSS_sub.pdf (501.75 Ko) Télécharger le fichier
GeMSS_sub (1).pdf (501.75 Ko) Télécharger le fichier
hal-03533455 , version 1 (18-01-2022)
hal-03533455 , version 2 (08-02-2023)
Paternité
John Baena, Pierre Briaud, Daniel Cabarcas, Ray Perlner, Daniel Smith-Tone, et al.. Improving Support-Minors rank attacks: applications to GeMSS and Rainbow. CRYPTO 2022 - 42nd Annual International Cryptology Conference, Aug 2022, Santa Barbara (CA), United States. pp.376--405, ⟨10.1007/978-3-031-15982-4_13⟩. ⟨hal-03533455v2⟩
164 Consultations
569 Téléchargements
