Implementation and validation of a second-moment RANS turbulence model in OpenFOAM ® - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The implementation and validation of the second-moment Elliptic Blending Reynolds Stress Model (EB-RSM) proposed by Manceau and Hanjalic is presented. The EB-RSM implementation is based on the finite-volume method available in the open-source OpenFOAM framework. Simulation results are compared against high-fidelity numerical solutions corresponding to test cases selected from the ERCOFTAC database involving flows with attached and separated boundary layers and streamline curvature effects. The performance of the second order model is also assessed by comparison with results obtained with low-Reynolds eddy-viscosity turbulence models.
Saldia2021.pdf (61.72 Mo) Télécharger le fichier
hal-03536915 , version 1 (20-01-2022)
  • HAL Id : hal-03536915 , version 1
Juan P Saldía, Sergio Elaskar, Luis F Gutiérrez Marcantoni, Pascal Bruel. Implementation and validation of a second-moment RANS turbulence model in OpenFOAM ®. MECOM 2021 - 37° Congreso Argentino de Mecánica Computacional, Nov 2021, Resistencia, Argentina. ⟨hal-03536915⟩
99 Consultations
58 Téléchargements
