A relational shape abstract domain - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Formal Methods in System Design Année : 2021
Static analyses aim at inferring semantic properties of programs. We distinguish two important classes of static analyses: state analyses and relational analyses. While state analyses aim at computing an over-approximation of reachable states of programs, relational analyses aim at computing functional properties over the input-output states of programs. Several advantages of relational analyses are their ability to analyze incomplete programs, such as libraries or classes, but also to make the analysis modular, using input-output relations as composable summaries for procedures. In the case of numerical programs, several analyses have been proposed that utilize relational numerical abstract domains to describe relations. On the other hand, designing abstractions for relations over input-output memory states and taking shapes into account is challenging. In this paper, we propose a set of novel logical connectives to describe such relations, which are inspired by separation logic. This logic can express that certain memory areas are unchanged, freshly allocated, or freed, or that only part of the memory was modified. Using these connectives, we build an abstract domain and design a static analysis that over-approximates relations over memory states containing inductive structures. We implement this analysis and report on the analysis of basic libraries of programs manipulating lists and trees.
main 2.pdf (448.13 Ko) Télécharger le fichier
hal-03538097 , version 1 (06-05-2021)
hal-03538097 , version 2 (20-01-2022)
Hugo Illous, Matthieu Lemerre, Xavier Rival. A relational shape abstract domain. Formal Methods in System Design, 2021, ⟨10.1007/s10703-021-00366-4⟩. ⟨hal-03538097v2⟩
112 Consultations
252 Téléchargements
