Stability properties for a problem of light scattering in a dispersive metallic domain - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Evolution Equations and Control Theory Année : 2023
In this work, we study the well-posedness and some stability properties of a PDE system that models the propagation of light in a metallic domain with a hole. This model takes into account the dispersive properties of the metal. It consists of a linear coupling between Maxwell's equations and a wave type system. We prove that the problem is well posed for several types of boundary conditions. Furthermore, we show that it is polynomially stable and that the exponential stability is conditional on the exponential stability of the Maxwell system.
NiSc21.pdf (477.21 Ko) Télécharger le fichier
hal-03540550 , version 1 (24-01-2022)
Paternité
Serge Nicaise, Claire Scheid. Stability properties for a problem of light scattering in a dispersive metallic domain. Evolution Equations and Control Theory, 2023, 12 (1), pp.20. ⟨10.3934/eect.2022020⟩. ⟨hal-03540550⟩
66 Consultations
39 Téléchargements
