Where, when and how people move in large-scale urban networks: the Grenoble saga - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2022
Ujjwal Pratap
Federica Garin
This work studies the mobility of people in the metropolitan city Grenoble in France, building a supply-demand based mobility model which captures the daily movement of people between residences and places of interests called destinations, using time schedules and gating profiles which also accommodate the possibility of imposing restrictions on mobility. The goal of this paper is to build the mobility network in Grenoble answering the three main questions (WWH): Where does mobility happen? When does it happen? How many people move? We provide methods to compute the time gating functions and different parameters for this network. Further, we identify and address the issues encountered during discretization of the continuous-time mobility model. As an application, we also study how different restrictions on the mobility effects the epidemic spread in Grenoble. Finally, we describe the online GTL-covid demonstrator which is being developed by implementing the results of this paper. It is an academic platform which can be used to simulate different scenarios of mobility and visualise its effect on epidemic spread in Grenoble area.
WWH_mobility_feb_3.pdf (21.18 Mo) Télécharger le fichier
hal-03554612 , version 1 (03-02-2022)
  • HAL Id : hal-03554612 , version 1
Ujjwal Pratap, Carlos Canudas de Wit, Federica Garin. Where, when and how people move in large-scale urban networks: the Grenoble saga. 2022. ⟨hal-03554612⟩
175 Consultations
68 Téléchargements
