Long-range promoter–enhancer contacts are conserved during evolution and contribute to gene expression robustness - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Genome Research Année : 2022
Gene expression is regulated through complex molecular interactions, involving cis -acting elements that can be situated far away from their target genes. Data on long-range contacts between promoters and regulatory elements are rapidly accumulating. However, it remains unclear how these regulatory relationships evolve and how they contribute to the establishment of robust gene expression profiles. Here, we address these questions by comparing genome-wide maps of promoter-centered chromatin contacts in mouse and human. We show that there is significant evolutionary conservation of cis -regulatory landscapes, indicating that selective pressures act to preserve not only regulatory element sequences but also their chromatin contacts with target genes. The extent of evolutionary conservation is remarkable for long-range promoter–enhancer contacts, illustrating how the structure of regulatory landscapes constrains large-scale genome evolution. We show that the evolution of cis -regulatory landscapes, measured in terms of distal element sequences, synteny, or contacts with target genes, is significantly associated with gene expression evolution.
Laverre2022.full.pdf (544.76 Ko) Télécharger le fichier
hal-03559410 , version 1 (10-11-2022)
Alexandre Laverré, Eric Tannier, Anamaria Necsulea. Long-range promoter–enhancer contacts are conserved during evolution and contribute to gene expression robustness. Genome Research, 2022, 32 (2), pp.280-296. ⟨10.1101/gr.275901.121⟩. ⟨hal-03559410⟩
163 Consultations
27 Téléchargements
