Optimal control approaches for Open Pit planning - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2023
This work tackles the Open Pit planning problem in an optimal control framework. We study the optimality conditions for the so-called continuous formulation using Pontryagin's Maximum Principle, and introduce a new, semicontinuous formulation that can handle the optimization of a 2D mine profile. Numerical simulations are provided for several test cases, including global optimization for the 1D Final Open Pit, and first results for the 2D Sequential Open Pit. Results indicate a good consistency between the different approaches, and with the theoretical optimality conditions.
manuscript_vf.pdf (1.61 Mo) Télécharger le fichier
hal-03588436 , version 1 (24-02-2022)
hal-03588436 , version 2 (22-03-2023)
  • HAL Id : hal-03588436 , version 2
Emilio Molina, Pierre Martinon, Pierre Martinon, Héctor Rámirez. Optimal control approaches for Open Pit planning. 2023. ⟨hal-03588436v2⟩
117 Consultations
106 Téléchargements
