Dirac equation as a quantum walk over the honeycomb and triangular lattices - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2018
A discrete-time Quantum Walk (QW) is essentially an operator driving the evolution of a single particle on the lattice, through local unitaries. Some QWs admit a continuum limit, leading to well-known physics partial differential equations, such as the Dirac equation. We show that these simulation results need not rely on the grid: the Dirac equation in (2+1)–dimensions can also be simulated, through local unitaries, on the honeycomb or the triangular lattice, both of interest in the study of quantum propagation on the non-rectangular grids, as in graphene-like materials. The latter, in particular, we argue, opens the door for a generalization of the Dirac equation to arbitrary discrete surfaces.
1803.01015.pdf (275.15 Ko) Télécharger le fichier
hal-03594743 , version 1 (05-09-2023)
Pablo Arrighi, Di Molfetta Giuseppe, Iván Márquez-Martín, Armando Pérez. Dirac equation as a quantum walk over the honeycomb and triangular lattices. 2023. ⟨hal-03594743⟩
294 Consultations
37 Téléchargements
