Automatic Rigid Registration of Aortic Aneurysm Arterial System - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2022
An abdominal aortic aneurysm is defined as a local and abnormal dilation of the aortic wall that can lead to rupture and death without treatment. A useful tool for the patient's postoperative follow-up is segmentation registration to see the evolution of the aneurysm between two examinations. Here, we propose a method to automatically register the entire arterial system: the segmentation is divided in three parts (suprarenal, infrarenal zone, and iliac arteries) and each part is registered separately. We chose a rigid point set to point set registration through the iterative closest point algorithm. We also compute the displacement fields and derive a criterion to accept or reject the registration of the infrarenal zone and iliac arteries. Registration is successful in 96% of cases for the infrarenal zone, in 94% for the suprarenal zone and in 65% for the iliac arteries.
main.pdf (4.03 Mo) Télécharger le fichier
hal-03600571 , version 1 (07-03-2022)
  • HAL Id : hal-03600571 , version 1
Gwladys Ravon, Florian Bernard, Angelo Iollo, Caroline Caradu. Automatic Rigid Registration of Aortic Aneurysm Arterial System. 2022. ⟨hal-03600571⟩
149 Consultations
36 Téléchargements
