Primality Tests and Prime Certificate - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2022
This note presents a formalisation done in Coq of Lucas-Lehmer test and Pocklington certificate for prime numbers. They both are direct consequences of Fermat little theorem. Fermat little theorem is proved using elementary group theory and in particular Lagrange theorem.
Note.pdf (123.35 Ko) Télécharger le fichier
hal-03601611 , version 1 (08-03-2022)
Laurent Théry. Primality Tests and Prime Certificate. 2022. ⟨hal-03601611⟩
87 Consultations
56 Téléchargements
