Semiclassical spectral gaps of the 3D Neumann Laplacian with constant magnetic field - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2022
This article deals with the spectral analysis of the semiclassical Neumann magnetic Laplacian on a smooth bounded domain in dimension three. When the magnetic field is constant and in the semiclassical limit, we establish a four-term asymptotic expansion of the low-lying eigenvalues, involving a geometric quantity along the apparent contour of the domain in the direction of the field. In particular, we prove that they are simple.
HR22.pdf (681.36 Ko) Télécharger le fichier
hal-03606341 , version 1 (11-03-2022)
  • HAL Id : hal-03606341 , version 1
Frédéric Hérau, Nicolas Raymond. Semiclassical spectral gaps of the 3D Neumann Laplacian with constant magnetic field. 2022. ⟨hal-03606341⟩
90 Consultations
47 Téléchargements
