Frequency Fitting Optimization Using Evolutionary Algorithm in Cochlear Implant Users with Bimodal Binaural Hearing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Brain Sciences Année : 2022
Alexis Saadoun
Antoine Schein
  • Fonction : Auteur
Vincent Péan
  • Fonction : Auteur
Pierrick Legrand
  • Fonction : Auteur
Ludwig Serge Aho Glélé
Alexis Bozorg Grayeli
Optimizing hearing in patients with a unilateral cochlear implant (CI) and contralateral acoustic hearing is a challenge. Evolutionary algorithms (EA) can explore a large set of potential solutions in a stochastic manner to approach the optimum of a minimization problem. The objective of this study was to develop and evaluate an EA-based protocol to modify the default frequency settings of a MAP (fMAP) of the CI in patients with bimodal hearing. Methods: This monocentric prospective study included 27 adult CI users (with post-lingual deafness and contralateral functional hearing). A fitting program based on EA was developed to approach the best fMAP. Generated fMAPs were tested by speech recognition (word recognition score, WRS) in noise and free-field-like conditions. By combining these first fMAPs and adding some random changes, a total of 13 fMAPs over 3 generations were produced. Participants were evaluated before and 45 to 60 days after the fitting by WRS in noise and questionnaires on global sound quality and music perception in bimodal binaural conditions. Results: WRS in noise improved with the EA-based fitting in comparison to the default fMAP (41.67 ± 9.70% versus 64.63 ± 16.34%, respectively, p = 0.0001, signed-rank test). The global sound quality and music perception were also improved, as judged by ratings on questionnaires and scales. Finally, most patients chose to keep the new fitting definitively. Conclusions: By modifying the default fMAPs, the EA improved the speech discrimination in noise and the sound quality in bimodal binaural conditions.
hal-03610651 , version 1 (16-03-2022)
Alexis Saadoun, Antoine Schein, Vincent Péan, Pierrick Legrand, Ludwig Serge Aho Glélé, et al.. Frequency Fitting Optimization Using Evolutionary Algorithm in Cochlear Implant Users with Bimodal Binaural Hearing. Brain Sciences, 2022, 12 (2), pp.253. ⟨10.3390/brainsci12020253⟩. ⟨hal-03610651⟩
16 Consultations
0 Téléchargements
