Haptic Rattle: Multi-Modal Rendering of Virtual Objects Inside a Hollow Container - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The sense of touch plays a strong role in the perception of the properties and characteristics of hollow objects. The action of shaking a hollow container to get an insight of its content is a natural and common interaction. In this paper, we present a multi-modal rendering approach for the simulation of virtual moving objects inside a hollow container, based on the combination of haptic and audio cues generated by voice-coils actuators and high-fidelity headphones, respectively. We conducted a user study. Thirty participants were asked to interact with a target cylindrical hollow object and estimate the number of moving objects inside, relying on haptic feedback only, audio feedback only, or a combination of both. Results indicate that the combination of various senses is important in the perception of the content of a container.
Hummel_Eurohaptics2022.pdf (2.78 Mo) Télécharger le fichier
hal-03614072 , version 1 (19-03-2022)
Paternité
Emilie Hummel, Claudio Pacchierotti, Valérie Gouranton, Ronan Gaugne, Théophane Nicolas, et al.. Haptic Rattle: Multi-Modal Rendering of Virtual Objects Inside a Hollow Container. EuroHaptics 2022 - International conference on Haptics: Science, Technology, Applications, May 2022, Hamburg, Germany. pp.1-8, ⟨10.1007/978-3-031-06249-0_22⟩. ⟨hal-03614072⟩
131 Consultations
144 Téléchargements
