Moderate deviations for the current and tagged particle in symmetric simple exclusion processes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2022
We prove moderate deviation principles for the tagged particle position and current in one dimensional symmetric simple exclusion processes. There is at most one particle per site. A particle jumps to one of its two neighbors at rate 1/2, and the jump is suppressed if there is already one at the target site. We distinguish one particular particle which is called the tagged particle. We first establish a variational formula for the moderate deviation rate functions of the tagged particle positions based on moderate deviation principles from hydrodynamic limit proved by Gao and Quastel [6]. Then we construct a minimizer of the variational formula and obtain explicit expressions for the moderate deviation rate functions.
tagged.pdf (186.07 Ko) Télécharger le fichier
hal-03619413 , version 1 (25-03-2022)
  • HAL Id : hal-03619413 , version 1
Xiaofeng Xue, Linjie Zhao. Moderate deviations for the current and tagged particle in symmetric simple exclusion processes. 2022. ⟨hal-03619413⟩
29 Consultations
41 Téléchargements
