Binary Multi Channel Morphological Neural Network - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2022
Neural networks and particularly Deep learning have been comparatively little studied from the theoretical point of view. Conversely, Mathematical Morphology is a discipline with solid theoretical foundations. We combine these domains to propose a new type of neural architecture that is theoretically more explainable. We introduce a Binary Morphological Neural Network (BiMoNN) built upon the convolutional neural network. We design it for learning morphological networks with binary inputs and outputs. We demonstrate an equivalence between BiMoNNs and morphological operators that we can use to binarize entire networks. These can learn classical morphological operators and show promising results on a medical imaging application.
Bimonn_DGMM_2022_Preprint_for_Arxiv.pdf (774.71 Ko) Télécharger le fichier
hal-03644498 , version 1 (19-04-2022)
  • HAL Id : hal-03644498 , version 1
Théodore Aouad, Hugues Talbot. Binary Multi Channel Morphological Neural Network. 2022. ⟨hal-03644498⟩
88 Consultations
36 Téléchargements
