Analytics on Non-Normalized Data Sources: more Learning, rather than more Cleaning - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Access Année : 2022
Data analysis is increasingly performed over data assembled from uncontrolled sources, facing inconsistency in knowledge-representation conventions. The typical practice is to create "clean" data for analysis, matching entities and merging variants to overcome differences in knowledge representation. Despite progress in data management techniques to automate this process, it still needs labor-intensive supervision from the analyst. In this paper, we evaluate the benefit of advanced statistical tools to address directly many analytic tasks across data sources without such entity-matching cleaning. Reframing analytical questions as machine-learning tasks enables to replace exact matching of entities by continuous descriptions-vectorial embeddings-that expose similarities between entries. But are analyses with less cleaning trustworthy? We answer this question with a thorough benchmark on questions typical of socioeconomic studies across 14 employee databases: we compare the approaches based on machine learning to manual data cleaning (entity matching). It reveals that using embeddings and machine learning improves results validity (smaller estimation error) more than manual cleaning, with considerably less human labor. While machine learning is often combined with data management for the purpose of cleaning, our study suggests that using it directly for analysis is beneficial because it captures ambiguities hard to represent during curation.
final.pdf (3.98 Mo) Télécharger le fichier
hal-03647434 , version 1 (20-04-2022)
hal-03647434 , version 2 (25-04-2022)
Alexis Cvetkov-Iliev, Alexandre Allauzen, Gaël Varoquaux. Analytics on Non-Normalized Data Sources: more Learning, rather than more Cleaning. IEEE Access, In press, 10, pp.42420-42431. ⟨10.1109/ACCESS.2022.3168013⟩. ⟨hal-03647434v2⟩
172 Consultations
161 Téléchargements
