Choice of mixture Poisson models based on Extreme value theory - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2022
Count data are omnipresent in many applied fields, often with overdispersion due to an excess of zeroes or extreme values. With mixtures of Poisson distributions representing an elegant and appealing modelling strategy, we focus here on the challenging problem of identifying a suitable mixing distribution and study how extreme value theory can be used. We propose an original strategy to select the most appropriate candidate among three categories: Fréchet, Gumbel and pseudo-Gumbel. Such an approach is presented with the aid of a decision tree and evaluated with numerical simulations.
VALIQUETTE_Samuel - Article submission.pdf (370.86 Ko) Télécharger le fichier
hal-03648664 , version 1 (22-04-2022)
Samuel Valiquette, Frédéric Mortier, Jean Peyhardi, Gwladys Toulemonde. Choice of mixture Poisson models based on Extreme value theory. 2022. ⟨hal-03648664⟩
139 Consultations
189 Téléchargements
