Iterative static ∆B0 field map estimation for off-resonance correction in non-Cartesian susceptibility weighted imaging - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Magnetic Resonance in Medicine Année : 2022
Patient-induced inhomogeneities in the magnetic field cause distortions and blurring during acquisitions with long readouts such as in susceptibility-weighted imaging (SWI). Most correction methods require collecting an additional ∆B 0 field map to remove these artifacts. The static ∆B0 field map can be approximated with an acceptable error directly from a single echo acquisition in SWI. The main component of the observed phase is linearly related to ∆B0 and the echo time TE , and the relative impact of non-∆B0 terms becomes insignificant with TE > 20ms at 3T for a well-tuned system. The main step is to combine and unfold the multi-channel phase maps wrapped many times, and several competing algorithms are compared for this purpose. Four in vivo brain data sets collected using the recently proposed 3D SPARKLING readouts are used to assess the proposed method. The estimated 3D field maps generated with a 0.6 mm isotropic spatial resolution provide overall similar off-resonance corrections compared to reference corrections based on an external ∆B0 acquisitions, and even improved for two out of four individuals. Although a small estimation error is expected, no aftermath was observed in the proposed corrections, while degradations were observed in the references. A static ∆B0 field map estimation method was proposed to take advantage of acquisitions with long echo times, and outperformed the reference technique based on an external field map. The difference can be attributed to an inherent robustness to mismatches between volumes and external ∆B0 maps, and diverse other sources investigated.
2022_article_mrm_b0_estimation.pdf (73.2 Mo) Télécharger le fichier
2022_supplementary_mrm_b0_estimation.pdf (13.61 Mo) Télécharger le fichier
hal-03650758 , version 1 (25-04-2022)
  • HAL Id : hal-03650758 , version 1
Guillaume Daval-Frérot, Aurélien Massire, Boris Mailhé, Mariappan S. Nadar, Alexandre Vignaud, et al.. Iterative static ∆B0 field map estimation for off-resonance correction in non-Cartesian susceptibility weighted imaging. Magnetic Resonance in Medicine, In press. ⟨hal-03650758⟩
87 Consultations
16 Téléchargements
