KartoGraphI: Drawing a Map of Linked Data - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Poster Année : 2022
A large number of semantic Web knowledge bases have been developed and published on the Web. To help the user identify the knowledge bases relevant for a given problem, and estimate their usability, we propose a declarative indexing framework and an associated visualization Web application, KartoGraphI. It provides an overview of important characteristics for more than 400 knowledge bases including, for instance, dataset location, SPARQL compatibility level, shared vocabularies, etc.
Mots clés
pd_Maillot_et_al_paper_208.pdf (434.8 Ko) Télécharger le fichier
hal-03652865 , version 1 (27-04-2022)
hal-03652865 , version 2 (08-06-2022)
Copyright (Tous droits réservés)
  • HAL Id : hal-03652865 , version 2
Pierre Maillot, Olivier Corby, Catherine Faron, Fabien Gandon, Franck Michel. KartoGraphI: Drawing a Map of Linked Data. ESWC 2022 - 19th European Semantic Web Conferences, May 2022, Hersonissos, Greece. Springer. ⟨hal-03652865v2⟩
161 Consultations
79 Téléchargements
