Riemannian channel selection for BCI with between-session non-stationarity reduction capabilities - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Neural Systems and Rehabilitation Engineering Année : 2022
Objective: Between-session non-stationarity is a major challenge of current Brain-Computer Interfaces (BCIs) that affects system performance. In this paper, we investigate the use of channel selection for reducing between-session non-stationarity with Riemannian BCI classifiers. We use the Riemannian geometry framework of covariance matrices due to its robustness and promising performances. Current Riemannian channel selection methods do not consider between-session non-stationarity and are usually tested on a single session. Here, we propose a new channel selection approach that specifically considers non-stationarity effects and is assessed on multi-session BCI data sets. Methods: We remove the least significant channels using a sequential floating backward selection search strategy. Our contributions include: 1) quantifying the non-stationarity effects on brain activity in multi-class problems by different criteria in a Riemannian framework and 2) a method to predict whether BCI performance can improve using channel selection. Results: We evaluate the proposed approaches on three multi-session and multi-class mental tasks (MT)-based BCI datasets. They could lead to significant improvements in performance as compared to using all channels for datasets affected by between-session non-stationarity and to significant superiority to the state-of-the-art Riemannian channel selection methods over all datasets, notably when selecting small channel set sizes. Conclusion: Reducing non-stationarity by channel selection could significantly improve Riemannian BCI classification accuracy. Significance: Our proposed channel selection approach contributes to make Riemannian BCI classifiers more robust to between-session non-stationarities.
IEEE_TNSRE_2022.pdf (1.19 Mo) Télécharger le fichier
hal-03654590 , version 1 (28-04-2022)
Khadijeh Sadatnejad, Fabien Lotte. Riemannian channel selection for BCI with between-session non-stationarity reduction capabilities. IEEE Transactions on Neural Systems and Rehabilitation Engineering, 2022, pp.10. ⟨10.1109/TNSRE.2022.3167262⟩. ⟨hal-03654590⟩
32 Consultations
69 Téléchargements
