How can we define the presymptomatic C9orf72 disease in 2022? An overview on the current definitions of preclinical and prodromal phases - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Revue Neurologique Année : 2022
Repeat expansions in C9orf72 gene are the main genetic cause of frontotemporal dementia, amyotrophic lateral sclerosis and related phenotypes. With the advent of disease-modifying treatments, the presymptomatic disease phase is getting increasing interest as an ideal time window in which innovant therapeutic approaches could be administered. Recommendations issued from international study groups distinguish between a preclinical disease stage, during which lesions accumulate in absence of any symptoms or signs, and a prodromal stage, marked by the appearance the first subtle cognitive, behavioral, psychiatric and motor signs, before the full-blown disease. This paper summarizes the current definitions and criteria for these stages, in particular focusing on how fluid-based, neuroimaging and cognitive biomarkers can be useful to monitor disease trajectory across the presymptomatic phase, as well as to detect the earliest signs of clinical conversion. Continuous advances in the knowledge of C9orf72 pathophysiology, and the integration of biomarkers in the clinical evaluation of mutation carriers will allow a better diagnostic definition of C9orf72 disease spectrum from the earliest stages, with relevant impact on the possibility of disease prevention.
Saracino_2022.pdf (693.76 Ko) Télécharger le fichier
hal-03664701 , version 1 (11-05-2022)
Dario Saracino, Isabelle Le Ber. How can we define the presymptomatic C9orf72 disease in 2022? An overview on the current definitions of preclinical and prodromal phases. Revue Neurologique, In press, ⟨10.1016/j.neurol.2022.03.007⟩. ⟨hal-03664701⟩
36 Consultations
344 Téléchargements
