A mathematical model to study the impact of intra-tumour heterogeneity on anti-tumour CD8+ T cell immune response - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Theoretical Biology Année : 2022
Intra-tumour heterogeneity (ITH) has a strong impact on the efficacy of the immune re-sponse against solid tumours. The number of sub-populations of cancer cells expressing different antigens and the percentage of immunogenic cells (i.e. tumour cells that are effectively targeted by immune cells) in a tumour are both expressions of ITH. Here, we present a spatially explicit stochastic individual-based model of the interaction dynamics between tumour cells and CD8+ T cells, which makes it possible to dissect out the specific impact of these two expressions of ITH on anti-tumour immune response. The set-up of numerical simulations of the model is defined so as to mimic scenarios considered in previous experimental studies. Moreover, the ability of the model to qualitatively reproduce experimental observations of successful and unsuccessful immune surveillance is demonstrated. First, the results of numerical simulations of this model indicate that the presence of a larger number of sub-populations of tumour cells that express different antigens is associated with a reduced ability of CD8+ T cells to mount an effective anti-tumour immune response. Secondly, the presence of a larger percentage of tumour cells that are not effectively targeted by CD8+ T cells may reduce the effectiveness of anti-tumour immunity. Ultimately, the mathematical model presented in this paper may provide a framework to help biologists and clinicians to better understand the mechanisms that are responsible for the emergence of different outcomes of immunotherapy.
hal-03673890 , version 1 (20-05-2022)
Emma Leschiera, Tommaso Lorenzi, Shensi Shen, Luis Almeida, Chloe Audebert. A mathematical model to study the impact of intra-tumour heterogeneity on anti-tumour CD8+ T cell immune response. Journal of Theoretical Biology, 2022, 538, pp.111028. ⟨10.1016/j.jtbi.2022.111028⟩. ⟨hal-03673890⟩
16 Consultations
0 Téléchargements
