Serodolin, a β-arrestin–biased ligand of 5-HT 7 receptor, attenuates pain-related behaviors - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Proceedings of the National Academy of Sciences of the United States of America Année : 2022
Chayma El Khamlichi
Fahima Madouri
  • Fonction : Auteur
  • PersonId : 779153
  • IdRef : 185601057
Cyril Colas
Gérald Guillaumet
  • Fonction : Auteur
  • PersonId : 964449
  • IdRef : 060700777
Franck Suzenet
Transmembrane signaling through G protein–coupled receptors (GPCRs), originally described as requiring coupling to intracellular G proteins, also uses G protein–independent pathways through β-arrestin recruitment. Biased ligands, by favoring one of the multiple bioactive conformations of GPCRs, allow selective signaling through either of these pathways. Here, we identified Serodolin as the first β-arrestin–biased agonist of the serotonin 5-HT 7 receptor. This new ligand, while acting as an inverse agonist on G s signaling, selectively induces ERK activation in a β-arrestin–dependent way. Importantly, we report that Serodolin decreases pain intensity caused by thermal, mechanical, or inflammatory stimuli. Our findings suggest that targeting the 5-HT 7 R with β-arrestin–biased ligand could be a valid alternative strategy to the use of opioids for the relief of pain.
pnas.2118847119.pdf (1.33 Mo) Télécharger le fichier
hal-03684955 , version 1 (28-07-2022)
Paternité - Pas d'utilisation commerciale - Pas de modification
Chayma El Khamlichi, Flora Reverchon, Nadège Hervouet-Coste, Elodie Robin, Nicolas Chopin, et al.. Serodolin, a β-arrestin–biased ligand of 5-HT 7 receptor, attenuates pain-related behaviors. Proceedings of the National Academy of Sciences of the United States of America, 2022, 119 (21), pp.1-12. ⟨10.1073/pnas.2118847119⟩. ⟨hal-03684955⟩
201 Consultations
201 Téléchargements
