Black-box optimization under constraints: simple selection algorithms and heuristic criteria - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 2022
This report was done during the Semaine d' Études Mathématiques et Entreprises (SEME) at the Institut de recherche mathématique de Rennes (IRMAR). The subject, proposed by the research centers Cenearo and IRT Saint Exupéry, is about the characterization of optimization problems which can only be tested under a black-box procedure. We propose some selection criteria in order to categorize such problems.
BlackBoxOptimization.pdf (1016.62 Ko) Télécharger le fichier
hal-03686642 , version 1 (02-06-2022)
  • HAL Id : hal-03686642 , version 1
Étienne Bellin, Quentin Chauleur, Samuel Guilluy, Rima Khouja, Ahmadou Sylla. Black-box optimization under constraints: simple selection algorithms and heuristic criteria. [Research Report] IRMAR - Université Rennes 1. 2022. ⟨hal-03686642⟩
161 Consultations
111 Téléchargements
