Pharo with Style - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Ouvrage (Y Compris Édition Critique Et Traduction) Année : 2022
Pharo with Style
Pharo is a modern, dynamically-typed, reflective, and pure object- oriented programming language. It offers strong productivity via a fully live programming environment. It supports Xtreme TDD, a powerful development technique that puts live objects at the center of the coding experience. More information at http : // www. pharo. org. Pharoers are used to say that programmers will never program the same once they coded seriously in Pharo. Learning Pharo is easy. Software developers learn Pharo in a couple of days. In addition, you can follow an excellent online free lecture available at : http : //mooc. pharo. org. Now programming is not only code logic but communicating with other developers via code. Pharo with Style, intended for both students and developers, defines a list of guidelines to help you writing better communicating code. Pharo with Style will bring you fast to the next level : You will code like the pros.
PharoWithStyle.pdf (485.38 Ko) Télécharger le fichier
hal-02299550 , version 1 (27-09-2019)
hal-02299550 , version 2 (29-09-2021)
hal-02299550 , version 3 (03-06-2022)
  • HAL Id : hal-02299550 , version 3
Stéphane Ducasse. Pharo with Style. Books on Demand, 2022. ⟨hal-02299550v3⟩
172 Consultations
393 Téléchargements
