Towards Corecursion Without Corecursion in Coq - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2022
Coinduction is an important concept in functional programming. To formally prove properties of corecursive functions one can try to define them in a proof assistant such as Coq. But there are limitations on the functions that can be defined. In particular, corecursive calls must occur directly under a call to a constructor, without any calls to other recursive functions in between. In this paper we show how a partially ordered set endowed with a notion of approximation can be organized as a Complete Partial Order. This makes it possible to define corecursive functions without using Coq's corecursion, as the unique solution of a fixpoint equation, thereby escaping Coq's builtin limitations.
wpte2022.pdf (236.2 Ko) Télécharger le fichier
hal-03689027 , version 1 (06-06-2022)
hal-03689027 , version 2 (27-06-2022)
hal-03689027 , version 3 (30-06-2022)
hal-03689027 , version 4 (15-08-2022)
  • HAL Id : hal-03689027 , version 4
Vlad Rusu, David Nowak. Towards Corecursion Without Corecursion in Coq. 2022. ⟨hal-03689027v4⟩
135 Consultations
76 Téléchargements
