Trustworthy automation for large-scale collaboration: a proposed exploratory study - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Automatisation digne de confiance de la collaboration à grande échelle : proposition d'étude exploratoire
With collaboration happening on an ever-larger scale, problems arise. Automation is a possible technology that could help make large-scale collaborations more efficient. We interest ourselves in how automation integration can be done without introducing additional troubles and propose a research protocol to investigate the effects of automation on collaboration with regard to trust.
AMIOT_AutomationXP22.pdf (398.5 Ko) Télécharger le fichier
hal-03697875 , version 1 (17-06-2022)
  • HAL Id : hal-03697875 , version 1
Clélie Amiot, François Charoy, Jérôme Dinet. Trustworthy automation for large-scale collaboration: a proposed exploratory study. AutomationXP22: Engaging with Automation, Workshop at CHI'22, Apr 2022, New Orleans (Louisiana), United States. ⟨hal-03697875⟩
93 Consultations
70 Téléchargements
