Vector Extensions of Halanay's Inequality - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Automatic Control Année : 2022
We provide two extensions of Halanay's inequality, where the scalar function in the usual Halanay's inequality is replaced by a vector valued function, under a Metzler condition. We provide an easily checked necessary and sufficient condition for asymptotic convergence of the function to the zero vector in the time invariant case. For time-varying cases, we provide a sufficient condition for this convergence, which can be easily checked when the systems are periodic. We illustrate our results in cases that are beyond the scope of prior asymptotic stability results.
Automatique
vectorkrstic.pdf (254.53 Ko) Télécharger le fichier
hal-03711578 , version 1 (01-07-2022)
Frederic Mazenc, Michael Malisoff, Miroslav Krstic. Vector Extensions of Halanay's Inequality. IEEE Transactions on Automatic Control, 2022, ⟨10.1109/TAC.2021.3062565⟩. ⟨hal-03711578⟩
34 Consultations
51 Téléchargements
