StAMP: Static Analysis of Memory access Profiles for real-time tasks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Accesses to shared resources in multi-core systems raise predictability issues. The delay in accessing a resource for a task executing on a core depends on concurrent resource sharing from tasks executing on the other cores. In this paper, we present StAMP, a compiler technique that splits the code of tasks into a sequence of code intervals intervals, each with a distinct worst-case memory access profile. The intervals identified by StAMP can serve as inputs to scheduling techniques for a tight calculation of worst-case delays of memory accesses. The provided information can also ease the design of mechanisms that avoid and/or control interference between tasks at run-time. An important feature of StAMP compared to related work lies in its ability to link back time intervals to unique locations in the code of tasks, allowing easy implementation of elaborate run-time decisions related to interference management.
OASIcs-WCET-2022-1.pdf (660.38 Ko) Télécharger le fichier
hal-03723457 , version 1 (06-12-2022)
Paternité
Théo Degioanni, Isabelle Puaut. StAMP: Static Analysis of Memory access Profiles for real-time tasks. WCET 2022 - 20th International Workshop on Worst-Case Execution Time Analysis, Jul 2022, Modena, Italy. ⟨10.4230/OASIcs.WCET.2022.1⟩. ⟨hal-03723457⟩
93 Consultations
52 Téléchargements
