Why do tree-based models still outperform deep learning on typical tabular data? - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
While deep learning has enabled tremendous progress on text and image datasets, its superiority on tabular data is not clear. We contribute extensive benchmarks of standard and novel deep learning methods as well as tree-based models such as XGBoost and Random Forests, across a large number of datasets and hyperparameter combinations. We define a standard set of 48 datasets from varied domains with clear characteristics of tabular data and a benchmarking methodology account- ing for both fitting models and finding good hyperparameters. Results show that tree-based models remain state-of-the-art on medium-sized data (∼10K samples) even without accounting for their superior speed. To understand this gap, we conduct an empirical investigation into the differing inductive biases of tree-based models and neural networks. This leads to a series of challenges which should guide researchers aiming to build tabular-specific neural network: 1. be robust to uninformative features, 2. preserve the orientation of the data, and 3. be able to easily learn irregular functions. To stimulate research on tabular architectures, we contribute a standard benchmark and raw data for baselines: every point of a 20 000 compute hours hyperparameter search for each learner.
Tabular_NeurIPS2022 (28).pdf (5.15 Mo) Télécharger le fichier
hal-03723551 , version 1 (15-07-2022)
hal-03723551 , version 2 (19-10-2022)
hal-03723551 , version 3 (27-06-2023)
Léo Grinsztajn, Edouard Oyallon, Gaël Varoquaux. Why do tree-based models still outperform deep learning on typical tabular data?. 36th Conference on Neural Information Processing Systems (NeurIPS 2022) Track on Datasets and Benchmarks, Nov 2022, New Orleans, United States. ⟨hal-03723551v3⟩
22809 Consultations
3041 Téléchargements
