Graph Querying for Semantic Annotations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Maxime Amblard
Bruno Guillaume
Siyana Pavlova
Guy Perrier
  • Fonction : Auteur
  • PersonId : 8101
  • IdHAL : guy-perrier
This paper presents how the online tool GREW-MATCH can be used to make queries and visualise data from existing semantically annotated corpora. A dedicated syntax is available to construct simple to complex queries and execute them against a corpus. Such queries give transverse views of the annotated data, these views can help for checking the consistency of annotations in one corpus or across several corpora. GREW-MATCH can then be seen as an error mining tool: when inconsistencies are detected, it helps finding the sentences which should be fixed. Finally, GREW-MATCH can also be used as a side tool to assist annotation tasks helping to find annotation examples in existing corpora to be compared to the data to be annotated.
2022.isa18-1.13.pdf (617.44 Ko) Télécharger le fichier
hal-03724068 , version 1 (22-07-2022)
Maxime Amblard, Bruno Guillaume, Siyana Pavlova, Guy Perrier. Graph Querying for Semantic Annotations. ISA 2022 : 18th Joint ACL - ISO Workshop on Interoperable Semantic Annotation, Jun 2022, Marseille, France. ⟨hal-03724068⟩
47 Consultations
42 Téléchargements
